Larry Bryzelak
Any good clutching setups for a 99 srx 600? Just want something for the trail. I have no studs with a 1 1/4 track. I weigh 230 lb.
A couple of bucks
From the clutch set-ups page:
53/43 Helix, stock weights w/ 4.5g rivet in 1st hole and 4.5g in tip, stock springs.
A couple of bucks
Give him a phone call for the fastest response. He's not on here much. There are a few in his list that will work fine.
http://www.totallyamaha.net/forums/...aring-Etc?p=675506&highlight=Helix#post675506
The Max 52/44 or the recut 52/45.
Larry Bryzelak
Ok cool thanks.
Larry Bryzelak
Where would I get the parts for this setup?
Someone on here might have parts you need. I used bolts and nuts for my weights. Lock tight the nuts.
A couple of bucks
JERSEYJOE
I agree this is a good low buck set-up
Larry Bryzelak
What about the helix? I can't find one.
yamahamark
A couple of bucks
You could try to pm this fella. Don't know if he still has it though.
http://www.totallyamaha.net/forums/threads/83566-Bender-Helix?highlight=Bender+9870
fastsrx
There's one on Grand Rapids,Mi Craigslist, but it was in November. Its a 51/43. You could give him a call. I run 8bu-10 at 49.5 grams with a gwg spring & 2 shims.
A couple of bucks
Howsahemi might still have his. Post #10
http://www.totallyamaha.net/forums/threads/63318-where-to-buy-yamaha-helix-s
