1987 Exciter Clutch Tune up kit
SpartaSXr
Western Michigan
Buddy has a 87 Exciter that the primary has seen better days. I look at the tune up kit for the 87 and it is no longer avaliable. Will a tune up kit for a 93 Exciter work ? The bushing numbers are the same but the kit was a 82M and is a 88R now. Just want a good answer before I put over $ 100.00 out for parts. Thanks ROCK ON SNOW THIS WEEKEND
Not even close. Totally different clutches and componets all together. 89X-00000-50-00 Will have everything you need except possibly the roller bushings. Yamaha used two different rollers that were different i.d. that used different bushings. The kit may come with new rollers with bushings intalled, but Im not sure. You can use either roller.
