rcrx5
Anyone know how to replace the TPS? I notice that it uses two security torx screws. Is this simply a plug and go? Mine is broken at the top, unable to plug the electrical contact in. Does not seem to effect how it runs though.
yes, you remove the 2 torx screws and install the new one, you do need to set the voltage values according to the service manual, that's why theres slots in the tps sensor to adjust the setting..
