I have a 96 vmax 600 crank seal at clutch side is leaking question is do I have to split the block to replace the seal or I can put screw in the seal to pull it out and install the new one?
yamahamark
You can put the seal in with out taking it apart but it is a real P.I.T.A... All you need is a seal tool for cars or tractor.
Nice I was hoping to not take it all apart after everything I did. all bring my tool from work
to put it in youll need to at least loosen the bottomend/case and install the seal, the case halfs have a coating of yamabond on them to seal out airleaks, but this isn't too bad of a job if you put the engine on a bench and do it. The crankseals have a lip around the outside of them that fits in a groove in the case, and the case exerts pressure on the outside to have a air tight seal, to get it in without loosening up the case crush youd destroy it and at least damage it.
you can take a small drill bit and drill a couple holes in the motor mounts to align when you replace the engine if you don't have the offset and center to center tool, drain coolant, unhook lines and set it on the bench. Youll get a repair the right way that will last and not cause you more grief later.
opsled
Listen to mrviper . He is correct...
opsled
opsled
Throttle Junkie35
A sled's worst nightmare is applying automotive/farm techniques when wrenching on them.
A couple of bucks
Jethro ......... Hand me that thar BFH.A sled's worst nightmare is applying automotive/farm techniques when wrenching on them.
Throttle Junkie35
Now thats funny right there..i dont care who you are.
