SXR 700 bogging when revs drop.
sleddog1
St.Catharines ,Ontario
While riding the sled ,sometimes the sled will have to come to a complete stop before I can get going again.This happens when you just back off the throttle while riding . The RPM has to drop down to about 1500 before she kicks back in. TORS switch?? Do you think I should disconnect it? Thats the only thing I can think of.
Yes tors. My srx did that exact same thing. cleaned the switch and it is perfect now. There is a write up in the tech section on how to clean the switch. very easy. Just make sure you turn the screw the correct way. It is reverse thread.
