This is a neighbors sled and he asked if i would assist in putting a new track in.The stock track is 133.5 and no longer made, 136 is looking like easiest new option. So in order to make this swap I can move the skid back 1.25"
Or maybe not sure if this is an option or not I read some guys ran there track tension all the way out and it worked, so I was thinking maybe that and add 7" wheels. Is this even possible? How much larger can you get away with and not wreck the wheels because obviously it will also stick out below the slide rail. This is an older gentlemen thats not going to ride aggressively.
