badazzyammie
How many washers can u run befor u run into clearance issues with the spider?
Middle/tip just add and check clearance as you go. Be careful to keep length of screws if you have to cut so you don't end up with to short screws. Heel washers are outside clutch.
badazzyammie
Yea I know that heel are out above the clutch I was just wondering because I have 7 grams in the tip and she is running at 8600 rpm could be the belt it has a few miles on it
that's real close, drop the secondary back to 60 and rerun it, it likely will go faster and be spot on
badazzyammie
Ok will do! Thanks mr viper
I'm running 7-8 grams on the tip and 7 in the heel
what helix?How many washers can u run befor u run into clearance issues with the spider?
badazzyammie
