oil pump ?
Mine did that and I think it was grime and oil and road junk built up and the spring could not over come the resistance.
my sxr did this once. i noticed it when i was cleaning the carbs in july, it hadn't been run since april. i cleaned everything and it didn't help. however this problem went away after i started it up in the fall.... weird.
I had my pump replaced since the original was starting to ooze oil around the seal and minute bubbles. Its going through a lot more oil now and was thirsty before. A tank half of gas and the oil jug is way down. The mark for open trottle is right. But I am sure its really running rich. I'll like to lean it back somewhat.
You have to get a precise amount used then adjust the cable accordingly
