Best pipes for srx
stock pipes will provide the best consistant performance, they will support engine mods all the way to 165-168hp, at that point they don't flow enough and you need to go to the bender big bore pipes, but the stock pipes are very,very hard to beat. Yamaha really did their homework on them!
Yeah that's what I've noticed found one set but they were for a red head and ok mr viper thanks for the info
power inc went out of business a long time ago and I would imagine they are getting pretty hard to find now, they also made a suitcase style silencer for the pipes. They don't have shielding on the pipes like the factory ones do, and if they get snowdust and etc. on them will drop rpm-max power very easily. They also only made barely any more hp then stock. The biggest benefit with them was the weight shavings but again, the weight vs the consistant performance, I would use the stock pipes if it were my sled but that's just my opinion. good luck .
10.68 on my 2000 srx best ever on tar. 1/4. i found a set of power inc on our local craigslist. i bolted them on with new rings and not with the power inc can. stk yamaha can. same driver 10.48 e.t. they do add power. time slips to prove it. 3:16x (yammie tony)
Oh alright thanks for the info so for porting u think the stocker will be fine tho only other thing done to it is cold air kit and gutted air box and heelclickers
