primary roller diameter?
Yes I mean the roller pin size.
The rollers in my 97 are a little wore and I bought some 88r rollers dirt cheap and was wondering how much it would change. Rollers are the same outer but different pin sizes.
the inner axle size has zero bearing on rpm change, it was changed for better durability. The outer diameter is what changes the rpm and weight force.
