holy smokes
sinedar
sudbury
I have a Yamaha venture 600 triple machine that smokes too much any ideas how to adjust oil injection?
Before adjusting the oil you need to figure out what your fuel/oil ratio is. Then go from there these sleds tend to run a little on the rich side as they are built to carry a pretty heavy load.
To adjust just follow the cabel to the pump and loosen the nut and turn up or down but be sure not to lean it out to much.
