03 vmax 700 no spark
chascook
vt
03 vmax 700 rev electric start has no spark stator tested good power to key none coming out any way to bypass it and see if it will run thanks
you checked both fuses right? the fuse to check is the one off the key switch which is the red/yellow to red wire.
You cant just unplug the key switch on the dual bulb headlight sleds and it will run, you need to jump the red/yellow to the brown to get it to run( bypass key switch). It was on the single bulb headlight sleds you could simply unplug the switch and they would run but without tach and lights.
Both fuses seem to be good you can get a backfire out of it when you let off the key when trying to start it how can I jump the kill switch
