Single bulb to dual bulb
Srx700#1
Dryden
Can i simply use 2000 and up plastic/ windshield to convert a 98 srx single bulb to the 2000 and up srx dual bulb headlight?
Yes, but it takes a little more work to get them both lit. The stock setup doesn't produce enough juice. I'm still currently running with one of the 2 bulbs going.
Use two lower wattage bulbs. 2001+ gauge pod, windshield, headlight and upper headlight harness. This's is a plug and play mod.
good to know. but unless im going to double the light theres not really any reason to do it so.......
