Nebraska700MM
Can anyone in depth tell me how to distinguish the old shaft from the new one? Or pictures? Tia!
SRXtreme
The old shaft on the speedometer end has a 45* chamfer from the bearing surface to the end of the shaft. The newer shaft it has a slight step cut into it.................SRXtreme
Nebraska700MM
If I post a couple pictures would you be able to confirm if it is or not?
Nebraska700MM
SRXtreme
That's the old shaft!!!! Your 1st photo show the 45* chamfer......................SRXtreme
Nebraska700MM
Thank You for clearing that up for me!
