new to me 2001
captnviper
Lifetime Member
st paul
Picked it up today and the guy let me do a compression check and everything. Looks long traveled out front with stock spindles and trailing arms still, does anybody know whos long travel stuff this is? 1300 miles $1200
Its works shock drs. The guys moving out of state tomorrow wanted $1700 but I told him its just going to be a spare sled and what was his bottom line. 1 hour each way.
So I see the sway bar is original srx they put some spacers to make it work I assume a viper one will fit nicely. Also it still has the srx trailing arms should I consider viper arms instead?
that looks like a great deal, Works performance front shocks are good quality upgrades over stock, the Fast M10 is a vast improvement over the stock skid
That is the Fast BLT front end kit. It was to widen out and add suspension to match the Fast M10. I have some Works long travel front end shocks if anybody is interested. They have the triple rate spring.
So the srx trailing arms are just fine?
Cleaned carbs and pulled powervalves looks like nobody had ever had either out before, as the valves were all pulled thru, carbs were clean (bless non-Ethanol) but pretty sure nobody ever had them off screws looked new. All the cables plug wires everything still has little id or part numbers on them so the powervalves are pulled I can handle that, if its the only suprise. $1200 for sled, $78 for windshield, and $130 for valves should be up and running.
