Low voltage. Killed battery.
hereismylife
Pa
Website
www.hereismylife.com
03 viper er
Batt is good but killed the batt last night. Had to keep turning everything off one by one to keep the gauges working.
Got home after test run dealing with other problem. Tested the battery and it shows low voltage and when pull started it would drain the batt. Fully charged the batt. Starts right up. At idle it only shows 12.9 . Reving only goes to 13.
I read it should flash that there is low voltage? Is this true?
Thanks Joe
