lil3incher
I have noticed that on my Mountain Max the hand warmers no longer work, wondering what powers them, possible wire broken, and also the taillight works when started but do not light when I pull on the brake lever, any and all info on what to check would be appreciated , Thanks
check the bulb 1st for the brake light. it is a separate circuit for the tail light. if the bulb is good, start checking for power at the rear socket with the brakes applied and sled running. trace back from there for broken/disconnected wiring.
sry do not know enough on the hand warmers but the wiring/specs should be the same as an sxr 700.
