ThatBlueVmax
My sled bogs at 5500 RPM just a little bit but will barely give out power, then sometimes it wont bog at all and be fine, my belt squeals like a sob and bogs even more when it is on its side a bit. This is the most popular forum section and I think clutching is clutching so. Had crank seals, coil, fuel pump everything fuel related cleaned. Am narrowing it down to clutchs even though there both clean.
yamahamark
Adjust you belt deflection to stop the squealing.
ThatBlueVmax
Any idea what the bog is?
Youllbe2nd
Sounds like carb problem. Or broken motor mount perhaps
Sent from my E6560C using Tapatalk
ThatBlueVmax
Had the motor out all torqued to spec when we changed seals and carbs are clean and air to fuel mix is perfect same with jetting
drew24
Is it bogging when the rpms are climbing from idle or is it when you are going and let off and then get back on it? Also did you set the center to center and clutch alignment to specs?
ThatBlueVmax
Going and let off of it is when it starts bogging and didn't check alignment on clutches.
drew24
I would get the clutch alignment and make sure the center to center is right first. Also check the buttons on the secondary and see what holes the spring is in on the secondary.
Youllbe2nd
X2 drew
ThatBlueVmax
We put the spring in the second setting that it came with from factory and how do you aline a clutch? New sleds and I was wondering the buttons
ThatBlueVmax
We ordered buttons but not sure if will fix
yamahamark
Align the clutch with an alignment tool.
ThatBlueVmax
ALignment is perfect and changed rollers still does a bog once a while, weak secondary spring?
yamahamark
Is it possible for you to get a video of this happening it might help a little bit more.
Could possibly be spring.
A couple of bucks
If the secondary spring is too weak, it will not be strong/fast enough to get it back up to 1st gear...... (The top).
ThatBlueVmax
Sorry guys! Just blew a track today, slide went through track and broke 6 holes. Will get a video once its fixed, also posted about track lug height I can use etc on another post.
