gmbroofingltd
hey i have a 01 srx 700 with i think is a 06 vector skid from usa tracks. i rode the sled a few times and i feel that the front end is stearing hard. i weight around 130 and would wonder if there is anyone that has done the similar skid as i on there srx and would have any experience to set me up properly. would i need to place a longer travel shock in the front like the ones from a sx viper?
drew24
Is it steering hard when you go wot or just normal riding? The limiter strap might be too tight or the transfer rod might need adjusted or maybe both.
gmbroofingltd
normal riding
drew24
See which holes the limiter strap bolts are in. Might need to lengthen it. If betheviper sees this he would know more of where to set it.
gmbroofingltd
the limiter strap look to be quite loose when sitting on level ground. when I lift the back end of the sled, it goes up about 1.5'' before the limiter strap is tight. not sure if this info helps?
Look up bethevipers suspension setups. It explaines everything in there. Being a different suspension from another sled it needs to be setup for your SRX.
