TPS wire order 2000 srx
goody_700
waunakee, wi
Noticed on TPS harness, wire was broken. I took connector apart, fixed broken wire, but in my haste, didnt write down order of wires in harness to clip em back into connector. So, standing on clutch side, what order left to right are they in..i thought it was red/yellow stripe, green/yellow stripe, grey/black stripe.
Thanks for help.
OK, Code is gone! Thanks! Someone had it apart before, put black rtv over broken gray/black wire. And that wire was in the back, I know that for a fact when I took it apart. But it is back to correct order now.
Much thanks!
Sucked that grey/black wire broke right where it goes into connector, but able to salvage pin connector, get it about as good as new.
