Reverse beeper issue........
low slung
Newfoundland
My fathers 1996 ET410II had issues with its reverse beeper for the past 10 years.Whenever it goes into reverse the beeper will stay full on(one long buzzing sound:whine:)or not come on at all.Sometimes it will act normal(very rare)or come on halfways going into reverse.Just wondering is the buzzer to blame or is it the switch under the shift lever the issue?Don,t want to spend a fortune on parts troubleshooting(Just spent $330 CDN on my 04 warrior to fix a TORS issue(Carb switch)that still didn,t fix it:o|?
try testing it with a meter. if the power is steady from the switch, the beeper should be the problem.
