Strokn4yamz
Just picked up a red head, first non-pv 2stroke and was wondering if anyones ran srx reeds along with srx pipes on it..also was wondering what the word on removing gaskets are..remove couple layers, one layer on top along with stripping a bottom one? Or does a guy get away with removing just a layer or two on top only and good to go
yamahamark
I've seen some with the reeds but don't know about the pipes.
Head gasket mod. http://www.totallyamaha.com/snowmobiles/aaTECH/sxheadgasketmod.htm
Reed stopper notch if you don't use the srx reeds
yamahamark
http://www.totallyamaha.com/snowmobiles/aaTECH/ReedNotch/Reed_Notch.htm
Or you could do reed spacers.
A couple of bucks
SRX reeds will not fit w/o grinding. And modding SRX pipes to a redhead is rather pointless.
Strokn4yamz
Thats what i figured, ive got PI pipes and spacers on already but have a set of srx pipes sutting around and was
Just wondering about them
A couple of bucks
PI center or end dumps
SRXtreme
I run the SRX reed in my 700MM. It needs to be case ported though.I think there is a few running the pipes but IMHO not worth it when a used set of PI's or Bender's can be picked up cheap.......................SRXtreme
