Power valve pull thru or bad cable?
marty f
WATERTOWN,MN
I have religiously clean my power valves every year, I have had my Srx for 15 years..looks like pull thru?maybe just cables..does anybody have a set for sale?Mr vipee700 I think use to swap or exchange20160201_202819.jpg20160201_202539.jpg20160201_202700.jpg20160201_202539.jpg20160201_202700.jpg
This is a common problem. There's a couple of DIY cheap fixes that work well. At least to get you through the season. You can drill out the hole a bit and put some kind of steel Insert in there like a roll pin. One guy used stainless tube. Or you can fork out the dough and get a machinest to do it for you proper using the bolt method for like 100-150$
Sent from my E6560C using Tapatalk
You don't need a machinist. I have done more than a few with a drill, die grinder and a tap and die set. Cost to fix if you have drill bits and a cut off disc about 2 bucks.
