Big Block Bill
Had my Son's 2002 Viper on a 4 day trip last weekend in the UP and the last day it would not go over 60 MPH. It just Babbles @ 60 MPH. I just went through the carbs before we left. It there possibly a problem with the Power Valves sticking? When we changed the plugs #1 looked darker (Black) compared to #2 & #3 and there appeared to be vapors coming out of the spark plug hole of #1. Any help would be appreciated. It might be time for another Apex.
Thanks,
Big Block Bill
(2) 1979 SRX 440 - Original owner
(2) 2006 Apex GT & ER
2002 Viper
2000 SXR700
Thanks,
Big Block Bill
2002 Viper
2000 SXR700
Reeds are good and fuel filters have been changed recently?
yamahamark
Check clutches for wore out parts and belt deflection Is right.
compression, that is a lot of speed to lose, you may have a missing piston skirt or hole in your piston. Even with three power valves not open, would go faster than 60.
Youllbe2nd
Yep check compression.
Sent from my E6560C using Tapatalk
A couple of bucks
Does that thing have a "limp" mode if it senses there is a problem?
Big Block Bill
2002 Viper won't go over 60 mph
Compression test results: #1 105, #2 115, #3 115 Thanks for all the replys
Bill
Bill
Big Block Bill
I don't think it has a limp mode, and if did would it Limp Mode to 60 MPH? I did disconnect the TPS and tried it, no change. I have a SXR 700 that gave me fits with the TPS and I bypassed it 7 years ago and it has run Great ever since.
Bill
Bill
shaggyzr2
Do you mean TORS? SXR's didn't have a TPS.I don't think it has a limp mode, and if did would it Limp Mode to 60 MPH? I did disconnect the TPS and tried it, no change. I have a SXR 700 that gave me fits with the TPS and I bypassed it 7 years ago and it has run Great ever since.
Bill
Big Block Bill
Yes. Being a Master Certified ASE Automotive Technician since 1974 anything related to Throttle position to me is a TPS: Throttle Position Sensor. I did not know Yamaha called it TORS. Thank You for Educating me. I still believe due to the fact it was 45 degrees, my issue is temperature related more than anything else. We pulled it out of the trailer today and hanging on a Rack it pulls like crazy to 8,000 RPM's. Any Input? This Sle NEVER liked Warm Weather.
Bill
Bill
Youllbe2nd
Tors and tps, two different things mate
Youllbe2nd
Tors is a throttle overide system. A safety feature incorporated into your cdi. It stops the engine from revving high enough to engage the clutches ...3000 or so.
