gmbroofingltd
does anyone have any experience clutching a srx with a 128'' skid? p.s. I don't have any experience with clutches.
dakotaruston13
I have a SXViper 700 with a 136" long track conversion kit and i just did a HEEL CLICKER kit on it, with a few other mods, the clutch kit is the best bang for your buck and it totally changed my viper from bottom to top!!
Outta the hole its crazy fast with little track spin mid range is still strong and didnt take away any from the top end still does 120mph top end on the gauge
Would recommend the heel clicker set up to anyone if you got the money its the best kit out for the old yamaha's
780srxgeorge
When I did a 136 to my sled with studs.i went with a 39 on bottom w/ 23 top.a tall helix like 51-43 or 52 something will help.keep an eye on tac you need & 8500 rpm.she will hook & book.
cheapest way out is to use the stock 8dn20's with 4.5 rivets both holes, a white/white/white Yamaha primary spring, then get a 50/44 helix with a green dot Yamaha secondary spring. It will wake up the sled and youll have quite a bit better backshifting for on and off the gas.
