redbuckeye84
Working on my 03 mountain viper. I have my skid setup following BETHEVIPERS specs. When I'm sitting on the sled the transfer rod gap is 50/50 (I weigh about 200) when I get off the suspension doesn't recover all the way - it only comes up about 75% of the way leaving a 1/4" gap or so on the bottom side of control rod. If I manually lift the rear bumper it will then stay up. I have the FRA in the lower hole (which I believe is the stiffer location right?) and rear shock set on stiffest setting.
Is my rear shock weak? Or is it the spring? Or something else? Sled is entirely stock. Thanks for any help!!
super1c
Super Moderator
Sounds like weak spring. Spring is ride heigh and sag.
