goldfam71
Hello. Im at 3_4,000 elv. I have a bender pipe and a psi pipe. The bender pipe with stock carb and a 135 jet worked fine till it burn ptoside piston. Holein middle with deep melting towards the exhast.i putin 142.5 now over fuels.i need help on how to jet carb .and which pipe is best.
thanks
thanks
might i inquire on witch carb you have? some where butterfly carbs.
goldfam71
It is the stock 88 phazer carb with just main jet on bottom changed.
