Machined steering stem bushings
j5ferry1
Michigan
I don't normally feel the need to review or post about parts but I'm sure some of you on here would dig these... I was pulling my engine at the beginning of the season to replace an oil pump, my stock steering blocks were crazy sloppy and knew I was replacing them. I was thinking about getting some new oem blocks for cheap and grinding the stops to tighten them up but then... they will just wear again...and I'll have to pull the motor ect...replace again. So I ran across the OFT racing billet steering blocks for nytro apex ect... Kindy pricy ($40 a set) but I was really looking for a more permanent solution from stock... These are exactly what I wanted. Perfect fit, ZERO play. I've put about 350+miles on the sled since and I would highly recommend these. The play I had before drove me absolutely bonkers. I guess sometimes...it's the little things haha.
