SXVIPERGUY21
So i had my sled up north last weekend for the 4th time this year. Been running awesome no problems at all. So long story short i jumped off a bank that i didn't think was as big as it was and took a pretty good slam. once i went to punch it again it would take off then make a loud grind noise?! stopped right away opened the hood nothing looked funny started it back up no lights on the dash or anything. tried to punch it from a lower speed and it happened again... if you pass maybe 20mph then open it up everything goes as it should. all my fluids are good, motor sounds fine, even runs fine until the grind. Anyone have an idea of what it could be? If i confused you with something just ask ill try to clear it up. Thanks.
