RX1 takes time to idel down
yama4you
Lino Lakes, MN
I have a 2003 RX1 and when driving and I back down off the throttle it does not go down to a low idle right away. I stop the idle is a little high about 2,00 to 3500 RPM and after a little bit it will drop to normal idle, also on the trail I have to apply the brake as it is slow to idle down. Thanks for any information, Dan
Sign up on the 4stroke side the guys over there will be able to help you more. Someone here's might be able to help as some of these guys have 4strokes as well.
Welcome to the site.
