JERSEYJOE
Can someone please post a picture showing the correct mounting of the coil pack on an srx engine?
JERSEYJOE
I just need a picture showing the coils mounted to the engine.
YAMMIEGOD3:16
joe they bolt to carb flanges. the wiring for them faces chaincase. they were wrong the picture you sent me. they should be underneath pv bracket. the plug wires flow to the right while siting on the sled. 3;16x (yammie tony)
I mount mine on the front of the head under two bolts to get them out of the way of boost bottle and looks pretty too.
they mount on three bolts on your reed cages if your into that stock look. the bracket is made to hold your oil cable from vibrating.
