ThatBlueVmax
Hello, Blew a track today on my VMAX slide went through it, was wondering what the max lug track I could put on it without different gearing and such, looking at a 1.5 inch lug camoplast for $300, not sure if will have enough clearance to not cause any problems like rubbing and hitting rads. Sled is a 1996 Yamaha VMAX 600, 121x15 inch track with 2.52 pitch.
yamahamark
You should be fine with 1.5 and you could always trim it if you need to.
A couple of bucks
1.5 will only fit with 8 tooth drivers. Which by the way is a kick arse upgrade over the .875 that's on it. 1 inch if your sticking with the stock 9 tooth.
Which 1.5 is available to you?
ThatBlueVmax
Ok was reading some people were saying they changed gearing etc but just looking for a easy track swap, how would you go about trimming?
ThatBlueVmax
1.5 camoplast track danny
A couple of bucks
Track trimming post #26.
http://www.totallyamaha.net/forums/threads/97649-96-XT6-to-144/page2
A couple of bucks
Here are some 8 tooth extroverts. I bought mine on here for $100 + shipping.
http://www.totallyamaha.net/forums/...l-running-sled-part-out/page2?highlight=tooth
http://www.totallyamaha.net/forums/...t-drivers?p=692073&highlight=tooth#post692073
ThatBlueVmax
Ok could a 1.25 lug work without gear changing? Just looking to change track
A couple of bucks
1.25 will be fine.
http://www.totallyamaha.net/forums/threads/69394-94-96-track?highlight=Driver+size
What kind of snow,trails,ditches,groomed, etc etc.
A couple of bucks
Here's a member in Houlton that might have a track or two.
http://www.totallyamaha.net/forums/members/3396-BETHEVIPER
ThatBlueVmax
Thanks picked up a 1 inch lug track with 144 studs should hook good compared to stock almost bald lugs to having studs and nice lugs.
caravanman
It sounds like yours is running well enough that you can still ride it (until the track damage).
My brother gave me a 1" studded Polaris track for my XT.
Mine still has good lugs on the ground but the drive lugs and studs are getting worn out after almost 10K miles.
Before next season I going to swap it and rebuild the shocks, it's been too long since I did those.
ThatBlueVmax
Yea, it's a rip saw 2, with 144 gold diggers
Vincent
Well-known member
Awsome to hear. I'm sure your new track will be a huge improvement!
