I installed boysen power reeds in my 01 srx 700. I'm only getting 8150rpms on hardpack/ice wide open. Could the reeds be causing this? Sled runs awesome but doesn't have the pop that it did.
I would lighten the tip weight.
Okay, I'm running 4.5 inner and 4.5 tip, have a yellow white yellow primary spring, 51/43 helix with green secondary spring
A couple of bucks
Everybody keep your flame guns holstered .... What's your wrap at?
also unless things have changed most people will tell you to stick with the stock Yamaha reeds
Youllbe2nd
Don't the power reeds have a bottom and a top? Have you got them in correctly?
Sent from my E6560C using Tapatalk
It's wrapped at 70 I believe. And the reeds are installed correctly. I had read before I purchased this brand that some had issues with pulling rpms...idk.
A couple of bucks
If you have to remove tip weight with the new reeds, that's telling me your making less power.
Youllbe2nd
Ya^^^
A couple of bucks
When I added Carbon Techs to my sons sled, I had to go up one rivet weight (I don't remember) to get peak back down. Im a thinkin it was .8 but had to go to a 2.4
I have read that they change jetting which makes sense since they are supposed to increase flow, I guess. Could it be its not at a optimal air fuel ratio therefore it's not making full use of the potential and if jetted for the reeds he would then pull the weight? I am just throwing out a theory, I'm interested in this topic. I have read don't get them unless, okay I have slp triples mrviper trail ported heelclicker setup, would this qualify for the above mentioned "unless" requirement?
A couple of bucks
Hummmm. I wonder if an air jet adjustment would make things right. Providing plugs and wash is ok.
Wash looks good, plugs too..
I would find a stock set and retest to eliminate other source for this issue.
Anyone know the best place to buy stock set? Prefer new
Mac
The cost is so low I would go to your local dealer as they will have them in 2-3 days.
Perfect...dealer it is
Let us know how it turns out.
