phazer II plywood seat base size?
snowdad4
southeast washington state
Did a quick search without results. Had these wrote down somewhere but cant seem to find that either. I know there was about 3" difference from the pz I's so I would take those dimensions as well.
I'm probably wrong but I think when I did mine I used 1/2 plywood so I would last a little longer and I think it was like 14 wide and 30 long. Not positive though because its been about 8 years and don't never write things down.
You might not like my answer's but I don't care 😊. My cousin is redoing his mountain lite seat and the base measures 13.5x22.5. Take it for what it is.
If you have the seat you could just measure it instead of searching online.
That must be one custom mtn lite or its not a pogo chassis. Cant really imagine a 13.5" plywood base on a 16" wide tunnel not to mention the fact that at 22.5" your either not covering the foam and connecting the front and rear plastics or making it back to the reinforcements for the rear seat bolts through the tunnel.
If I had a measurable seat at the time, I wouldnt have posed the question nor searched the innerweb. But, for the real world, the phazer II is 16" x 28.5" and the phazers are 16" x 25". Both are 3/16" thick but 1/4" works fine. I think both could get by at 15 3/4" or 15 7/8".
Sometimes a person can stand back, read, and learn and sometimes a person can admit when they are mistaken or really dont have a valid answer. Even better, if someone really doesnt have any first hand experience or knowledge, just skipping on to the next challenge may be a better choice.
I agree with your statement about standing back.
Also I didn't even know my cousin had bought a sled till today and I figured I would go ahead and get some measurements. His tunnel does look narrower and it doesn't have a vin #.
