drew24
01 srx stock 01 jetting,45 pilots, fuel screws at 1.75, haven't checked the needle setting yet. Rode 275 miles in mostly 30-35 degrees. Not sure if it would make a difference to the way they look but I did try to run it in colder temps at home but with the low snow I couldn't do much. Rode maybe 5 minutes in the colder temps after the trip. What do you guys think? From left to right Pto,middle,mag.Thanks![IMG_20160212_111316442[1].jpg IMG_20160212_111316442[1].jpg](https://totallyamaha.net/data/attachments/30/30497-02abf0523771f2a37f2b556e859639cf.jpg?hash=AqvwUjdx8q)
wildthangci
PTO looks rich, center and mag look good for those temps.
Sent from my XT1585 using Tapatalk
drew24
That's pretty much what I was thinking. Wish there was more snow so I could do some testing in colder temps.PTO looks rich, center and mag look good for those temps.
YAMMIEGOD3:16
very good. let it be rich 3:16x (yammie tony)
drew24
PTO had a broken power valve cable. That explains why that plug was black and why it wasn't pulling rpm. I just thought it was cause the temps got warm. After changing out the cable I found the broken cable was not moving very good. Must be why it broke. Thanks for the input guys
