Exciter primary
kubis21
Mn
Hey guys I'm new to the forum. Just looking for input on a 102c clutch for my 78 exciter 440. Just wondering if I can run a clutch without the gear for the oil injection, it quit working before i got the sled so I'm not concerned with trying to fix it. I know it will bolt up with the same taper but will the belt alignment be correct?
Welcome to the site.
Alignment shouldn't be a problem with a gearless clutch. You'll need to check the alignment and likely have to adjust it with a clutch swap anyway.
Thanks for the info...i decided to stick with the correct clutch, so my tach would at least work
