ThatBlueVmax
Hello! Was wondering on my sled sometimes when I let off and give it throttle it bogs some. Crank seals, carbs are clean, air/fuel mixture is right, clutches all cleaned and fuel pump clean and gas tank. What could it be? Thanks
Youllbe2nd
What sled is it
Sent from my E6560C using Tapatalk
ThatBlueVmax
Its a 96 600 vmax twin 2 stroke
Youllbe2nd
Check your reeds. Add reed spacers. Or better yet, put viper reed cages in it.
ThatBlueVmax
Someone reason I thought it was clutch wise as its not all the time it acts up, doesnt have anything wrong with reeds
A couple of bucks
Wont work on the 94-96 twins. Different bolt pattern.Or better yet, put viper reed cages in it.
Youllbe2nd
Ohhhh good info^^^ I just did a 97
A couple of bucks
Have you replace both clutch springs and belt?
ThatBlueVmax
Danny I remember you saying a weak secondary spring, ordered one from yamaha but they found the OEM part number for it but it matched a red spring instead of green it was the exact same PN # as factory, havent installed yet
ThatBlueVmax
And no only bought a secondary spring and its a brand new yamaha belt
YAMMIEGOD3:16
either clutching or a bad reed like posted. 3:16x (yammie tony)
A couple of bucks
If your reeds are tired, and they probably are, I very much like Carbon Tech reeds. And they help w/ any hard starting issues. They are on my 96, my sons redhead & my old(rip) 97 redhead.
http://www.carbontech.com/snow/yamaha.html
