SRX 440 Carburator problem
silverrocket
Quebec, Canada
i'm trying to figure out what to do to fix my carb issue. My issue is a hesitation on take off at full throttle. 8H0 cylinders, Aaen race pipes, 1976 heads, 42 mm Carburetor, 350 MJ,Thunder Power Jet (1/2 turn out) 50 Pilot Jet, Air screw 2 1/2 turn out, Needle Jet 7DH2 (middle position) Polaris P85 clutch, 10MR weights (39 grams), stock driven, 1 3/8 belt, engaging at 7,000 rpm. Everything works good except for the hesitation on take off.
