Does anybody know what the 1998 sx 700 dyno' is stock
REDMATER
tya
ny
Website
mysite.verizon.net
what did the sx700 out out in HP/TQ stock.i hear 111hp and another rumor is 114hp? any idea what the real deal is. :?: [/b]
Red- You are in that neighborhood of 110hp--the dyno reports depend on a lot of variables--just like on the trail. If you havent---pull a layer (or two) from your head gasket for an additional REAL 3-5 hp.
3-5 hp
do i gain 3hp with 2 gaskets,and 5hp with a single? is that how it works or just over all 3-5hp. i run 93 octane fuel is that hot enough
The hp increase again depends on a variety of things, but 3-5 hp is a range.
Removing 2 layers will put you on the higher hp end, and one layer less, but very effective. 93 octane is good. I personally would remove one gasket, because if you ever add pipes etc you cant have 2 layers out (yes its been done, but minimizes safety) You can see the tech area for a step by step, and you will not need to change jetting. cheapest hp around...
Good luck and enjoy your free hp. That sled will run well even with the relative low hp if tuned properly---primarily clutching.
John
THANKS FOR THE INFO
I HERE YOU JOHN, I HAVE BORED THE SILENCER AND HAVE BEEN TALKIN TO MR SLED ABOUT CLUTCHING WHICH IS ALL NEW TO ME. I WANT A GOOD TRAIL SET-UP I LIVE IN EDEN NY AND THE TRAILS AROND HERE ARE NARROW IN SOME AREAS BUT ALOT OF OPEN FIELDS TO HAUL THE MAIL. THIS SITE ROCKS! ANY IDEAS WILL BE CONSIDERED
