young james
Hello everyone!
I'm at my witts end with this sled. Can't get it going at all now. Before, she would run but not idle. You would have to hold throttle to the handle bars and pull the cord and take off. Had carburetor off 4 times and had it cleaned each time to no avail. Then we started reading about the throttle override system on these sleds. The way we found it was the 2 plugs on the carb was plugged into each other, and the 2 plugs in the harness on the skidoo was not pplugged into anything. When we plugged those 2 together on the sled, she would rev extremely high without touching the throttle when you pull the cord. Adjustment on the carb done nothing at all. However, the kill switch on the handle bars was missing, and the only thing left is the box for jt, and not the actual button to press. Someone told me problem could be in there. So we took that apart, and now we can't get it going at all. No matter what we try, we can't get it started whatsoever. This only happened when we took the kill switch apart. It was in real rough shape and everything pretty well tell apart when it took it apart. I think it was rolled at one point and it got damaged. Any help at all to get this going would be greatly appreciated!!
