twistedtattoo
I have a 98 srx 600 had the motor swapped for a 700 and have been fouling alot of plugs the last couple of weeks. it was running fine for the longest time has had proper service and everything. but im also finding that before the plugs foul i have a almost sucking noise and loss of power. i find this starts when im feathering it thru a long slower turn. if i run it full out it seems to be fine till i slow then i start to foul. i changed the plugs yesterday from br9es to br9ecs and found the sled is running alot rougher and it seems the right piston (throttle side) seems to be hitting harder than the other two any idea what could be causeing this
