700 Red Head Mountain Max coolant air bleeding help
lil3incher
Rushoon, Newfoundland and Labrador, Canada
I recently damaged the rear of my sled and had to remove the rear heat exchanger to repair it, Tried removing the bleeder screw in the rear, running the machine until air bubbles come out, then try topping up fluid through the coolant cap, the heat exchangers get hot but the one on the right side gets alot hotter than the other ones, i have already added about almost a liter of coolant and she is still not full, If any one can tell me step by step process it would be a big help, Starting to get fed up with it, shouldn't be this hard, any and all help will be great , thanks
