Power Valve cable to cylinder installation
Yink777
Minnesota
Hey guys I need help installing my power valve. I have not removed it from the servo, but just forgot which power valve cable goes with which cylinder or does it even matter? For example does cable 1 on the servo goes to the cylinder by the clutch?
ive always made sure to label each cable to make sure no confusion.. should be able to figure out which cable goes to which valve just by the length of them
Yes, cylinders are numbered left to right looking at the engine while sitting on the seat. The numbers inside the servo are cylinder numbers.
That's right^^ PTO - 1, mid - 2 and mag is 3. Take the servo cover off and you'll see the numbers. I think mag cable is longer.
Sent from my E6560C using Tapatalk
