guigui
Throttle Junkie35
Yep. very common to see wear or flaking (corrosion) on 25 year old + sleds. Exciter carbs on a Phazer Im guessing?
guigui
Yes in fact, those are exciter carbs on a phazer. But now I have a bigger issue. It runs quite lean on PTO side, it is not the carbs, I swapped them from side to side and the problem stayed on the same side. I thought it could be the crank seal but usually from my experience, when they go they leak oil and it does not seem to be the case. I sprayed carb cleaner on boots and did not notice any change in RPM
I guess I will be pulling the engine tonight to inspect it. Anyone know it you can pull the clutch as on a bombardier, with the clutch bolt, teflon tape and water?
nst115
VIP Lfietime Member
Yes clutch can be pulled with water,oil etc...
Sent from my XT1080 using Tapatalk
guigui
could this scoring on carb slides be enough to make them stick. I have a sticking carb problem. I guess for now I will put the original carbs back
Throttle Junkie35
Most likely not. Check the cable junction (tube) where the cable splits. It may have some hardend grease in it. Clean it out with a water based degreaser and lube it with something like fluid film that doesnt have any solvents. I damaged a cable once using something like Liquid wrench to lube it so now im very careful what I use to lube them.
On a side note, I have had slides get sticky (freeze up) when running in cold temps when the motor wasnt warmed up. This would be amplified if you werent running an air box.
