So on my SRX I noticed when I pull the Brake lever my rear Brake light doesn't want to go on,or it flickers slightly.Took the bulb out and replaced 2 times with other bulbs,same thing happens.But if I push the bulb in while on the Brake lever,the bulb lights up.So this tells me the socket contacts are worn down enough(thru vibration over the years)that the bulb won't make proper contact.Without replacing the socket,is there a way to build up the contacts in there??? Ohers must have had this problem in the past.Thanks in advance
Cooper0809
It's probably your brake lever switch that has failed slightly. That was my problem anyways...
Labrador-Ronin
Check the switch on the lever, if you change it and it's the same check wires
Sent from my D5106 using Tapatalk
will look into at then,so you thinks its not the socket end?????Why does bulb light up when I push it in tighter by hand while the lever is depressed?? Anyways not a biggie for me,still can ride the beast....nice day today for a ride...
Cooper0809
You got the right bulb? Lol
opsled
If you're pushing in on the bulb and it works I'd say you found the problem. Worn bulb contacts or ground connection would be my guess.
That tail light assembly was used on almost every two stroke sled Yamaha built since the mid 80's. Online says a complete new assembly is less than $20 US. Good used should be easy to find. New is cheap.
Repair or replace your choice.
opsled
opsled
