The ride before last involved some wet and slushy conditions.  Next time I rode the track was frozen stuck (or so I thought).  Eventually got it free by throttling and helping the track along by hand but when it came free there was a noticeable crack.  Thought it was just from ice.  Now there is a noticeable knocking noise that is cyclical.  I let it thaw out in the garage to rule out an ice chunk stuck up in the track.  The track wheels are fine.  Changed the belt but no change. Nothing seems to be broken underneath. Doesn't make the noise when the I jack the back end up and there isn't any weight on the track...Any ideas?
			goody_700
You have studs? Maybe a ripped out stud, or a lug ripped partially, knocking on tunnel, heat exchanger..just a thought.
			kingjames2330
Just did this on mine last year it's your lower drive shaft bearing.
Toxic hunter
			Toxic hunter
Check tension on chain. If to loose it will clunk bad
			Was the belt you tried new?   It's amazing how much noise/thunking a bad belt can produce
X2 - very often a flat/glazed spot on the belt causes this.
My thoughts as well...its amazing what havoc a damaged belt can cause.
