Labrador-Ronin
Hello all I have a used stator mailed to me, it came damaged.... The triple triangular connector shattered, two of the pluggins are out, can that be repaired, I mean can I splice my old ones wires onto this used one? And still be safe?
Sent from my D5106 using Tapatalk
If you look hard enough you can get that plug online. Likely shipped from China. Looks like the wire and prongs are fine, so all you have to do is snap a new plug housing in place as long as you get the same one.
If you can get a small enough screw driver or flat blade in there you should be able to get the plugs out of the plastic housing,or what's left of it.There'll be a small tang that angles slightly up that locks the plug into the housing and it's just a matter of flattening or pushing it down so the plug can be pulled out.If you can get the plugs out just bend the locking tangs back up a little bit and push the plugs into another housing in the correct pattern and with the correct side up.
