Limiter strap adjustment
Jimmy
Toronto
I have a 1995 Yamaha vmax600le that my daughter rides. The sled does not handle well fish tails at rear. My question is should I reduce the rear shock preload, adjust limiter straps and if so which strap front or rear and do I shorten or lengthen for better handling.
She is only 100 lbs
Best way to find out is to try various set ups yourself. Just document and keep track of each change. You'll probably find a better more balanced set up then anyone can suggest to you.
Just trying to find a starting point. Don't know anything about snowmobile suspension.
