84 Phazer carb removal
kloudkiker
Corvallis, OR
Help! How do I get the airbox off and out of the way so I can service these carbs? Not worried about it going back on, I'll install pods instead.
first with stock carbs you need to run the air box for them to function right .....that being said remove the snorkel from the box on the chain case side of the box
then remove belt and secondary clutch , next on the upper left hand side of the tank cover above the fuel fill door is a 1''x2'' rectangle plastic piece that pops out there are 2 10mm head bolts that need to be removed, them remove the 2 phillips head screws from the side vent, them remove clamps from carbs life up on tank cover plastic and wiggle airbox out
