justin1620
Hey fellas, does anybody have any tips on changing main jets quickly? I don't have much time tonight and I'd like to change my main jets for radar speed runs this weekend. Every time I change jets it takes me forever to get the sled started again because carb rail drains empty....maybe I can try and plug the carb rail fuel lines.....just wondering if anyone had any quick tricks lol
staggs65
pull the plugs and pour a small amount of mixed gas in the plug holes. doesn't take much. will fire right up
pull the vent line off behind the tank, blow into it then crimp it off, this pressurizes the tank. also if you know your doing this, flood the sled when you shut it off with the choke.
Dial a jet.................. works if you hook em up correct................
